My MicroSquirt Install |
McMark |
Jul 20 2008, 05:00 PM
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) |
McMark |
Jul 20 2008, 05:10 PM
Here is the wiring harness I had Jeff Keyzer make me. We sourced all the correct, uncrimped connectors so each connector could be attached directly to the harness wires.
The MicroSquirt unit is tiny, weatherproof, robotically soldered using surface mount components, and shielded from EMF. It was originally designed for motorcycles, but I think in our case, it's a much more appropriate choice than your standard MegaSquirt. The injector on the left is a custom made high-impedance injector that works perfectly in our manifolds with stock hold-downs, stock connectors, and will allow use of the stock fuel rails. No resistor packs necessary. (IMG:style_emoticons/default/thumb3d.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 09:34 AM |
