> Strut to a-arm to ball joint pin not fitting, did I get the wrong pin or will a bigger hammer work?
neo914-6
post Jul 21 2008, 09:14 PM
neo life
the strut hole and notch in the a-arm ball joint shaft:
the chamfered pin:
chris914
post Jul 22 2008, 04:20 AM
To get mine to align I used a jack to lift the arm. To protect the arm place a piece of wood between the two. Be careful not to push up on the heat shield.
neo914-6
post Jul 22 2008, 05:08 AM
neo life
QUOTE(chris914 @ Jul 22 2008, 03:20 AM) *
(IMG:style_emoticons/default/idea.gif) You may be on to something, my first pic shows the V notch isn't in the center of the hole likely because the strut bottom corner is hitting the hanging a-arm. Will jack it up and install the pin again...
- Lo-Fi Version Time is now: 14th December 2025 - 05:25 AM
