McMark |
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) ![]() ![]() |
McMark |
This setup will be expensive. But doing it right is usually not cheap.
MicroSquirt: $400 LC-1 WB-O2: $200 MAP: $64 TPS: $75 TPS Connector: $35 (this connector had to come from europe) (IMG:style_emoticons/default/sad.gif) Custom Injectors: $85 each, $340 for four Wiring Harness: price is not set but more than $400 Injector Connectors: $12 each, $48 for four I think when everything is done, it'll be around $2000 for the bolt in setup. I'm keeping drawings of my custom parts so that they can be laser/waterjet cut in the future. Everything will mount in the engine bay, so this will be a no cutting/modifying installation (except O2 sensor bung). Also, if everything goes according to plan, the stock fuel pump/fuel regulator will be used, which will save a significant amount of money and maintain a stock look. |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Rick_Eberle |
Member ![]() ![]() Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 07:39 PM |
