My MicroSquirt Install |
McMark |
Jul 20 2008, 05:00 PM
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) |
TimT |
Jul 22 2008, 07:01 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE he wasted spark setups that you (TimT) are using, are they built into the systems? Not so much that they are built into the system in that we configure the ECUs we use (Haltechs) for waste spark. It is all in the software configuration. We have been having a pretty good run lately installing about one per month E6X systems. Dont want to hijack McMarks thread to much but here are some installs... We usually use Bosch 3 channel ignition modules.. 3.7L Hi-output /6 coil board set up |
grantsfo |
Jul 23 2008, 09:16 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
QUOTE he wasted spark setups that you (TimT) are using, are they built into the systems? Not so much that they are built into the system in that we configure the ECUs we use (Haltechs) for waste spark. It is all in the software configuration. We have been having a pretty good run lately installing about one per month E6X systems. Dont want to hijack McMarks thread to much but here are some installs... We usually use Bosch 3 channel ignition modules.. 3.7L Hi-output /6 coil board set up Very nice! |
Lo-Fi Version | Time is now: 28th September 2024 - 12:55 PM |
