Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
Ok, while rebuilding the rotted out passenger longitudinal on my car I came up with an idea. How about a port that can be used for access to the interior of the longitudinal for inspection and other purposes. For example while my passenger side is going to be fine after I reconstruct it, I "think" the driver side is golden, however, I don't know for sure. Even if it is good, I would like to treat the interior of the driver side with some type of rust proofing (Metal Ready and then POR 15 most likely). But how do I get into that section without cutting a hole and then welding it back?
Here is my idea. In the front fender well there is a small area that if it had a port cut in, would allow you to view and/or access the entire length of the longitudinal. Items like the heater tubes and brackets will be somewhat in your way, but otherwise it is a straight shot down the length from here. I was thinking that a hole (maybe 1" in diameter or so) could be cut in the wall. Some type of "bung" (large diameter flat nut) could be welded in place and then a plug could be screwed into the bung. You could seal the threads with your sealent of choice, etc. to keep anything from getting in. An example of using this would be that a wand used to spray Metal Ready or thinned POR 15 should be easily snaked down the length via this. Every few years you could open it up and check to make sure things are OK. I don't like cutting up the car to do custom stuff, but I think this is maybe something I can live with. In the photo below is where I am thinking about doing this. ![]() I have looked at McMaster-Carr and I can't find a flat nut or some other type of weldable nut or bung that is of large enough diameter (1" or so). I think the plug is going to be easier to source than the bung. I would prefer metric threads, but I am thinking if I have any hope it might end up NPT or some other non-metric thread. Any ideas for source of a large diameter bung or how to create my own (i.e. thread 1/4" metal plate to make my own)? Is this a good idea or not? Opinions welcome! |
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
The heater tube blocks a good bit of the access through the long. There is already an access hole in the front portion of the long- accessable from the inside of the door jam, behind the speaker location. Can't see in there unless you have a boroscope, a viewier on a flexible wand. However, you can relatively easily access the front portion of the long with a flexible hose to flush it out, dry, and then apply a sealer inside. Also, as mentioned earlier, the oval ccess ports on the insides of the longs can be removed. I used a flexible hose from Eastwood that has a right angle sprayer attachment on the hose. This can be used to spray inside the long, passing it through first the front hole I just mentioned to get the front half of the long. Then you can use it to pass through the side hole to treat the rear half of the long. I sprayed POR 15 metal treatment stuff, and then rinsed very, very well. Let it dry for several days, then heated it with a hot air gun to remove all remaining moisture. Then sprayed the inside with POR 15. Should be pretty good for a while. Make sure that drain holes are still open after all this.
Lo-Fi Version | Time is now: 22nd June 2024 - 04:50 AM |
