> Strut to a-arm to ball joint pin not fitting, did I get the wrong pin or will a bigger hammer work?
neo914-6
post Jul 21 2008, 09:14 PM
neo life
the strut hole and notch in the a-arm ball joint shaft:
the chamfered pin:
914Sixer
post Jul 22 2008, 07:37 AM
Use a round punch to align hole. It seems like the wedge pin will only go in from the rear if I remember correctly.
neo914-6
post Jul 27 2008, 11:16 PM
neo life
QUOTE(914Sixer @ Jul 22 2008, 06:37 AM) *
That did it, Thanks for all the suggestions everyone!
One other problem I had was the hole was smaller than the dia of the pin because of the powdercoating. I had to file it with a rat tail file since I didn't have a drill slightly under 1/2" or a small honing tool. Ideally this should be done before mounting the strut... (IMG:style_emoticons/default/rolleyes.gif)
- Lo-Fi Version Time is now: 29th April 2025 - 06:26 PM
