> Good day turns bad, Master Cylinder?
jfort
post Aug 3 2008, 01:30 PM
finally get car all back together. Tach and shift light work. Clean it up for the triumphant, it all works, spin around the block. Car is running great. I'm flying down a country road with a smile on my face. This is what it's all about! Put on the breaks, I feel pedal "pop" and go to the floor. No brakes! Limp home. Reservoir is empty. Nothing at any caliper. A little fluid on garage floor under about the pedals. Master cylinder? I don't even know where it is, yet. Under gas tank? Behind pedal cluster? How does one get to the master cylinder? I am searching for my .pdf manual now. DAMN!
VaccaRabite
post Aug 3 2008, 01:54 PM
En Garde!
Check your 4 rubber lines between the wheels and the body and make sure none of them burst.
A "pop" indicates that something burst.
Zach
jfort   Good day turns bad   Aug 3 2008, 01:30 PM
davep   MC is on the other side of the pedal cluster below...   Aug 3 2008, 01:44 PM
Vacca Rabite   Check your 4 rubber lines between the wheels and t...   Aug 3 2008, 01:54 PM
pete-stevers   glad nothing more happened!! it coulda bee...   Aug 3 2008, 02:39 PM
jfort   you were exactly right, zach. after cooling off a...   Aug 3 2008, 02:50 PM
ArtechnikA   you were exactly right, zach. after cooling off ...   Aug 3 2008, 02:57 PM
jfort   OK, now you have me scared. the front line connec...   Aug 3 2008, 03:19 PM
Eric_Shea   Is it a family secret? :D BTW... the "tri...   Aug 3 2008, 03:57 PM
ArtechnikA   Is it a family secret? I didn't say it was ...   Aug 4 2008, 05:37 AM
Cap'n Krusty   This type of failure is a "feature" of S...   Aug 3 2008, 06:58 PM
Spoke   I just replaced all 4 braided flex lines on my 74....   Aug 4 2008, 07:43 AM
jfort   bought SS braided lines from PP. THEY DON'T F...   Aug 6 2008, 06:13 PM
Cap'n Krusty   Yet another "feature" of SS braided tefl...   Aug 6 2008, 06:17 PM
jfort   PP wasn't much help. "They've never ...   Aug 6 2008, 07:55 PM
ArtechnikA   PP wasn't much help. "They've never...   Aug 6 2008, 08:01 PM
Vacca Rabite   PP wasn't much help. "They've never...   Aug 6 2008, 08:02 PM
jfort   Zach, I didn't have the benefit of this threa...   Aug 6 2008, 08:14 PM
ArtechnikA   I pulled my aluminum calipers out of the box and h...   Aug 7 2008, 05:49 AM
jfort   to summarize, SS line from PP doesn't fit. bl...   Aug 7 2008, 06:12 PM
jfort   here is the other end   Aug 7 2008, 06:13 PM
jfort   here is the original plus the adapter   Aug 7 2008, 06:15 PM
jfort   sorry for being so fuzzy. here is the original fi...   Aug 7 2008, 06:19 PM
Phoenix 914-6GT   I have installed those same lines with no problem....   Aug 7 2008, 06:22 PM
jfort   yeh, it's weird. also, it looks like the two ...   Aug 7 2008, 06:32 PM
ArtechnikA   well - that's just whack... get some normal M...   Aug 7 2008, 06:55 PM
jfort   OK, you guys, I figured it out this morning at a b...   Aug 8 2008, 09:39 AM
Phoenix 914-6GT   :headbanger: Glad you figured it out. I wouldn...   Aug 8 2008, 02:00 PM
jfort   they were shitty SS hoses. very thin couplings. ...   Aug 9 2008, 06:23 AM
- Lo-Fi Version Time is now: 6th January 2025 - 10:00 PM
