> grind into first, second when hot, after adjusting clutch
pete-stevers
post Jul 28 2008, 11:43 AM
saved from fire!
Why after adjusting the clutch to a point where when engaging into first or second there are no grinds on a cold start....
but after the car is hot it begins to grind in first second, and third does not engage as well
does the cable expand this much from the heat??
Dr Evil
post Aug 9 2008, 02:33 PM
Send me your transmission!
If you are running out of thread on the cable end, which is a common occurrence, you can put a small piece of metal tubing on the end of the cable between the wedge block and the adjusting nut.
You do not need to drop the engine to remove the tranny! Its easier not to.
pete-stevers   grind into first, second when hot   Jul 28 2008, 11:43 AM
jasons   I have the same problem. It doesn't grind, bu...   Jul 28 2008, 12:18 PM
So.Cal.914   Story of my life. I think the cable streches when ...   Jul 28 2008, 12:23 PM
pete-stevers   is it the cable, the shift rod, or the tranny itse...   Jul 29 2008, 12:46 AM
jasons   My guess would be the cable. After thinking about...   Jul 29 2008, 09:49 AM
Bartlett 914   My first thought was about the oil. Seems to me th...   Jul 29 2008, 10:04 AM
Justinp71   Why after adjusting the clutch to a point where w...   Jul 29 2008, 10:09 AM
Dr Evil   Where does the clutch disengage in the pedal strok...   Jul 29 2008, 12:39 PM
orthobiz   Where does the clutch disengage in the pedal stro...   Jul 29 2008, 05:27 PM
Bleyseng   Where does the clutch disengage in the pedal stro...   Aug 9 2008, 02:01 PM
Dr Evil   Within the 1st 1/4 of travel is the 1st 1/4 of tra...   Jul 29 2008, 06:34 PM
orthobiz   Within the 1st 1/4 of travel is the 1st 1/4 of tr...   Jul 30 2008, 09:48 PM
Dr Evil   Within the 1st 1/4 of travel is the 1st 1/4 of t...   Jul 31 2008, 12:30 PM
James Adams   I think your bronze bushing is binding. You can...   Jul 29 2008, 08:05 PM
jasons   I think your bronze bushing is binding. You can...   Jul 29 2008, 08:36 PM
James Adams   Were talking about the console bushing correct? ...   Jul 29 2008, 08:48 PM
rufio0205   [quote name='James Adams' post='1061954' date='Ju...   Aug 10 2008, 01:54 PM
jasons   If the factory console bushing is eccentric, will ...   Jul 29 2008, 09:05 PM
James Adams   If the factory console bushing is eccentric, will...   Jul 29 2008, 09:29 PM
jasons   It's not eccentric, the sides of the inner ho...   Jul 29 2008, 10:45 PM
DNHunt   Proximal=toward the center Distal=away from the ce...   Jul 31 2008, 01:51 PM
Dr Evil   He started it with the proximal/distal talk :poke:   Jul 31 2008, 03:44 PM
Vacca Rabite   If you have a EuroRace header, it has been suggest...   Jul 31 2008, 05:23 PM
jasons   If you have a EuroRace header, it has been sugges...   Jul 31 2008, 06:07 PM
Dr Evil   You mean clutch cable, not pedal, right? :blink:   Jul 31 2008, 05:26 PM
orthobiz   OK. Doc is in medical school. He admits he should ...   Jul 31 2008, 08:06 PM
r_towle   yo, da cable be wrong...turn the nut till its righ...   Jul 31 2008, 08:11 PM
pete-stevers   does this issue have anything to do with the heat...   Aug 9 2008, 01:32 PM
pete-stevers   i was hoping not to drop the motor this winter..ag...   Aug 9 2008, 02:13 PM
Dr Evil   If you are running out of thread on the cable end,...   Aug 9 2008, 02:33 PM
wertygrog   not to hijack, but it seems to me with this clutch...   Aug 9 2008, 07:27 PM
Dr Evil   You did the adjustment right, but your theory is o...   Aug 9 2008, 07:40 PM
wertygrog   yes, thanks! :D   Aug 9 2008, 07:52 PM
rufio0205   i'm glad you guys are hashing this out because...   Aug 9 2008, 10:14 PM
Dr Evil   You dont shim the flywheel, you put a washer under...   Aug 9 2008, 11:18 PM
rufio0205   he adjusted the clutch but i have the same problem...   Aug 10 2008, 11:49 AM
Dr Evil   Thomas, I suspect that your clutch is not adjusted...   Aug 10 2008, 02:17 PM
drewvw   Mine used to do that when my engine ran really hot...   Aug 10 2008, 03:19 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 07:26 PM
