Oil Pressure Sensor Question |
pilothyer |
Aug 10 2008, 12:34 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I am sure this has been covered somewhere, but I can't seem to get the search to operate today, so here goes......Does the oil pressure sensor have continuity to ground and then as the pressure rises it opens the circuit to the oil light and turns it off ? If so I should get continuity between the threads on the sensor and the clip wire terminal...Is this correct ? Thanks for your reply........Jerry
ejm |
Aug 10 2008, 01:56 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,705 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Yes, the light is grounded thru the sensor. When pressure rises the switch opens and the light goes out.
Lo-Fi Version | Time is now: 26th December 2024 - 07:39 PM |
