> Oil Pressure Sensor Question
pilothyer
post Aug 10 2008, 12:34 PM
I am sure this has been covered somewhere, but I can't seem to get the search to operate today, so here goes......Does the oil pressure sensor have continuity to ground and then as the pressure rises it opens the circuit to the oil light and turns it off ? If so I should get continuity between the threads on the sensor and the clip wire terminal...Is this correct ? Thanks for your reply........Jerry
ejm
post Aug 10 2008, 01:56 PM
I can see the light at the end of the tunnel
Yes, the light is grounded thru the sensor. When pressure rises the switch opens and the light goes out.
pilothyer
post Aug 10 2008, 02:38 PM
QUOTE(ejm @ Aug 10 2008, 02:56 PM) *
Thanks for your reply.....that is what I thought. but when I tested the new sensor it had no continuity thru it..........guess I got a bad (new) one. (IMG:style_emoticons/default/mad.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 07:48 PM
