> Rear hub with 928 bearing and increased offset, 928 Hybrid trailing arm, 944 brakes, extended hub offset, parking brak
Wilhelm
post Aug 10 2008, 11:24 PM
Few pics of a project I'm working on to break up the misery or paint, bondo and rust removal on my V-8 SBC conversion. I'm going to do the sheridan body work on my car and found these wheels which I liked.
The problem is the wheels are 10 inches wide with an offset of 2 inches. In searching the web site it seems that most people with this combo have gone with 3" spacers. This seemed like it would put a lot of force on the bearing and I still would not have many other rear brake options. So.... I found some rear 928 hubs on ebay. the bearings are much larger: 85mm diameter and 47mm wide (versus stock 75mm diameter x 37mm long) and this would provide me with other 5 lug rear brake options. So off to the barn.
First, put a piece of 5 inch 1.25 inch wall DOM(Drawn Over Mandrel steel tubing) in the lathe.
sww914
post Aug 11 2008, 12:52 AM
What you've done looks great! Good ideas for sure.
My only concern now is all the extra torque that distance will put on the stock trailing arm. Do you plan to reinforce it somehow or deal with that problem if it arises?
Wilhelm
post Aug 11 2008, 02:03 AM
QUOTE(sww914 @ Aug 10 2008, 11:52 PM) *
Doubt moving the bearing outward transmits any additional torque to the trailing arm compared to a stock arm with a 3" spacer and this same wheel or a stock arm with a deep offset wide wheel and no spacer. This design puts a lot less torque on the bearing compared to a spacer setup. Plus the bearing is substantially hurkier. Certainly comparing this trailing arm to a stock one with a stock wheel there will be additional torque applied to the arm. I have a set of stock sheet metal arm reinforcements shells I can weld on, but my hunch is they are better at adding weight than strength. I did a search on arm reinforcements where tubes were welded across the insides of the trailing arms. Unfortunately the pics of this thread are all gone. Guess it was a proprietary secret? Think most likely I will run a diagonal from the hub adjacent to the back of the parking brake plate forward at 45 degrees to the outside of the trailing arm keeping it inside of the wheel rim. Anyone have better ideas?
PeeGreen 914
post Aug 11 2008, 02:19 AM
QUOTE(Wilhelm @ Aug 11 2008, 01:03 AM) *
Eric Shea does the tubes that strengthen the arms. I would think you would be well advised to do something like that as you are putting more stress on the arm. The bearing I am sure is fine but the arm is now the weak point. May be fine as it is though. Nice work (IMG:style_emoticons/default/aktion035.gif)
Wilhelm   Rear hub with 928 bearing and increased offset   Aug 10 2008, 11:24 PM
Wilhelm   Cut off everything that didn't look like rear ...   Aug 10 2008, 11:45 PM
Wilhelm   Found a some 11 gauge 4.75" outside diameter ...   Aug 10 2008, 11:48 PM
iamchappy   Impressive!....   Aug 10 2008, 11:51 PM
Wilhelm   Cut the old hub out of a 914 swing arm and than we...   Aug 10 2008, 11:58 PM
SirAndy   :trophy: how does the brake attach? :idea: Andy   Aug 11 2008, 12:30 AM
Wilhelm   :trophy: how does the brake attach? :idea: And...   Aug 11 2008, 12:43 AM
sww914   What you've done looks great! Good ideas f...   Aug 11 2008, 12:52 AM
Wilhelm   What you've done looks great! Good ideas ...   Aug 11 2008, 02:03 AM
Phoenix 914-6GT   What you've done looks great! Good ideas...   Aug 11 2008, 02:19 AM
Mikey914   Nice. Saw a set of turbo twisties on CL locally an...   Aug 11 2008, 01:06 AM
neo914-6   Excellent work and great idea!   Aug 11 2008, 01:42 AM
Wilhelm   Since I can add the brake bracket for my caliper e...   Aug 11 2008, 02:08 AM
Rick_Eberle   Since I can add the brake bracket for my caliper ...   Aug 11 2008, 02:25 AM
roadster fan   Nice work, wish I had some of those tools :worshi...   Aug 11 2008, 03:16 AM
Wilhelm   Thanks for the info on the reinforcements! Th...   Aug 18 2008, 09:18 PM
Wilhelm   Here are the parking brakes set in place without t...   Aug 18 2008, 09:24 PM
r_towle   awesome work... I agree that what you did will ad...   Aug 18 2008, 09:27 PM
Krieger914   Nice work. Do you think the axles are going to hi...   Aug 18 2008, 09:44 PM
John   Wow! That is some excellent thinking. Are yo...   Aug 18 2008, 10:28 PM
SGB   Simply amazing. Wow that sweet. :)   Aug 18 2008, 10:32 PM
Wilhelm   As the axle would be going into a deeper hole, the...   Aug 18 2008, 10:55 PM
Todd Enlund   Damn, dude... that rocks. :headbanger:   Aug 18 2008, 11:19 PM
Wilhelm   Forgot to add this should anyone else be intereste...   Aug 19 2008, 12:19 AM
andys   Wilhelm, Just catching up after 5 days in Puerto ...   Aug 20 2008, 04:13 PM
ClayPerrine   Wilhelm, Just catching up after 5 days in Puerto...   Aug 20 2008, 10:06 PM
burton73   Wilhelm, Just catching up after 5 days in Puert...   Dec 8 2008, 11:28 PM
ClayPerrine   [quote name='ClayPerrine' post='1069525' date='Au...   Dec 9 2008, 09:43 AM
Brett W   One thing to keep in mind, on a unit bearing like ...   Aug 20 2008, 06:26 PM
andys   Clay, I've read that opinion before, but unfo...   Aug 20 2008, 11:11 PM
ClayPerrine   Clay, I've read that opinion before, but unf...   Aug 21 2008, 12:55 PM
andys   Clay, I've read that opinion before, but un...   Aug 22 2008, 03:06 PM
Brett W   The Carrera GT used a spot type caliper. http://...   Aug 21 2008, 01:15 AM
ClayPerrine   The Carrera GT used a spot type caliper. http:/...   Aug 21 2008, 12:56 PM
McMark   Beautiful... :drooley:   Aug 21 2008, 03:00 AM
Phoenix 914-6GT   Ummm... Can I have that rear suspension? :D   Aug 21 2008, 03:15 AM
Wilhelm   "I curious why you chose the 928 bearing? Mos...   Aug 21 2008, 12:34 PM
andys   "I curious why you chose the 928 bearing? Mo...   Aug 21 2008, 12:59 PM
ClayPerrine   For what its worth, even Wilwood is using a parkbr...   Aug 21 2008, 01:10 PM
Brett W   Glad I haven't bought the Wilwood spot caliper...   Aug 21 2008, 04:27 PM
seanery   nice project! it's very cool!!...   Aug 21 2008, 04:41 PM
charliew   I don't know why this additional challenge occ...   Sep 18 2008, 11:46 AM
Lou W   Very nice work. :beer2:   Nov 30 2008, 05:54 AM
burton73   Clay, This was Rich’s answer to my email on the...   Dec 9 2008, 03:39 PM
charliew   Wilhelm I have been anxiously waiting to see the r...   Jan 24 2009, 07:54 PM
Wilhelm   I'm anxiously awaiting the solution too! ...   Jan 24 2009, 10:49 PM
charliew   Oh yeah I forget about the weather everywhere but ...   Jan 25 2009, 08:54 AM
- Lo-Fi Version Time is now: 29th April 2025 - 07:19 AM
