Electrical problems |
watsonrx13 |
Aug 13 2008, 07:01 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I've been trying to track down an electrical problem with my FI and I've found more problems.
1. When I turn on the ignition switch I blow fuse #9. The Haynes manual says that this fuse powers the turn signals, brake lights and back-up lights. Also, I noticed that the buzzer sounds when I turn on the key, regardless of both doors closed or open. Anyway, I disconnected the brake light switch at the brake pedal, all of the wires to the turn signals and disconnected the back-up light wire at the tranny but the fuse still blows, which then stops the buzzer. 2. No power to the coil. I've replaced the ignition switch with another one, but I'm still not getting any power at the coil. I've checked the continuity between the ignition switch and the coil. I have power to all pin #30s on the relay board in the engine compartment. I have power at the large red wire at the ignition switch. I feel that I'm very close to getting this car running, but with these electrical gremlins I'm extremely frustrated...(IMG:style_emoticons/default/mad.gif) Any suggestions and/or guidance would be greatly appreciated.... -- Rob |
orange914 |
Aug 14 2008, 10:35 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
so to summerize you found a incorrectly placed wire and switched it. you now have power to the fuel pump.
i have to assume the fuse still blows because you are tracing wires in your next post. did you double check that back up bulb socket has a single element bulb and the brake/driving light sockets have double element (and not installed 180* off)? mike |
Lo-Fi Version | Time is now: 26th June 2024 - 10:52 AM |
