finstermojo |
Newbie ![]() Group: Members Posts: 40 Joined: 10-November 07 From: new york Member No.: 8,314 ![]() |
I am finishing my Rabys 2316 and working on the full flow oil system and the line off the oil pump cover will need me to notch the engine mount out and install a 45 degree elbow so it can get out from the front. Has anybody else removed material off the mount so the fitting will fit. I attached the picture so you can see what i am talking about has anybody else had to deal with this? I also a included a pict of the entire engine with a single wire chevy 100 amp alternater installed.
Attached thumbnail(s) ![]() ![]() |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Matt, what happened to the manifolds we shipped with the heads?? The Pierce manifolds you picture are good for a solid 6% reduction in flow and that equates to a solid 10HP or MORE on that engine, plus they were match ported to the heads..
leave things as we Engineered them, else you'll never get the output of efficiency from the kit. Everything we provide is included for a reason. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Matt, what happened to the manifolds we shipped with the heads?? The Pierce manifolds you picture are good for a solid 6% reduction in flow and that equates to a solid 10HP or MORE on that engine, plus they were match ported to the heads.. leave things as we Engineered them, else you'll never get the output of efficiency from the kit. Everything we provide is included for a reason. Did you provide the valve covers? If so, are they leak proof??????????????????????? Not that I would LOVE a leak proof and easy to remove valve cover...lol Rich |
Lo-Fi Version | Time is now: 24th June 2024 - 07:27 AM |
