My Getty Dash is installed!, Finally got 'er done |
markb |
Aug 18 2008, 06:58 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
After having to learn a bit of upholstery stuff, I got the dash in today. Thankfully, the dash already had stitched vinyl on the majority, but I wanted tan near the windshield, where I need to put material anyway, so I learned a bit about cutting & gluing vinyl. I only had to pull it out twice! (IMG:style_emoticons/default/dry.gif)
Here's a few pics. I need to order a CHT/Volt gauge done up, so the fuel/oil level is just there for looks. I'll probably re-do the triple gauge with the stencils. |
Eric_Shea |
Aug 20 2008, 09:18 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE I'm guessing you found out the hard way about refinishing the spokes? Yeah. Dallas Custom was very nice. I called in advance and asked if they could perform this service. They stated "yes, it would be an additional $50.00." I thought that was reasonable if it was a proper refinish. It turned out to be 150 grit and a rattle can. Don was very cool about my concerns and he understood and immediately reversed the charge. While I didn't really want to repaint it myself, I was forced to. I sanded everything down, used the 3M blue tape and was able to slide it under the yoke tabs. I used 600 grit and applied 3 coats of semi-gloss, sanding after each coat. I "may" finish it off with some 0000 steel wool, maybe not. It looks good as is... (IMG:style_emoticons/default/idea.gif) Thanks again to Kelly and Mark Heard for the wheel and center piece. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:48 PM |
