> Rear hub with 928 bearing and increased offset, 928 Hybrid trailing arm, 944 brakes, extended hub offset, parking brak
Wilhelm
post Aug 10 2008, 11:24 PM
Few pics of a project I'm working on to break up the misery or paint, bondo and rust removal on my V-8 SBC conversion. I'm going to do the sheridan body work on my car and found these wheels which I liked.
The problem is the wheels are 10 inches wide with an offset of 2 inches. In searching the web site it seems that most people with this combo have gone with 3" spacers. This seemed like it would put a lot of force on the bearing and I still would not have many other rear brake options. So.... I found some rear 928 hubs on ebay. the bearings are much larger: 85mm diameter and 47mm wide (versus stock 75mm diameter x 37mm long) and this would provide me with other 5 lug rear brake options. So off to the barn.
First, put a piece of 5 inch 1.25 inch wall DOM(Drawn Over Mandrel steel tubing) in the lathe.
Wilhelm
post Aug 21 2008, 12:34 PM
"I curious why you chose the 928 bearing? Most think the 914 bearing is more than adequate, and the 911 bearing beyond most needs."
I have a 928 and am familiar with this so had a reference for it during the design phase. Also I got complete rear hubs/carriers/brakes shoe setup for both rear corners of ebay for $25.00 a pop, much cheaper than I saw for any 911 stuff. Like many of you I am a CSOB.
"You need to use a little more filler rod and a little less heat on your TIG welds. Looks like you have a little undercutting."
Thanks, I appreciate any tips. I'm early on in my TIG welding having done MIG for 25 years. While welding this I think I was concentrating more on good penetration and was trying to avoid melting filler onto my weld rather than integrating it into my weld. I can see that it requires more eye hand coordination than MIG. I find myself pausing, taking a deep breathe, and getting set, before running each bead. Seems like with MIG I've gotten used to hitting the trigger and running with it!
andys
post Aug 21 2008, 12:59 PM
QUOTE(Wilhelm @ Aug 21 2008, 11:34 AM) *
$25 bux is way cheap; I see your motivation.
Going from MIG to TIG, just slow down a bit and get used to using the pedal to control your heat. As they say, practice, etc.
Andys
Wilhelm   Rear hub with 928 bearing and increased offset   Aug 10 2008, 11:24 PM
Wilhelm   Cut off everything that didn't look like rear ...   Aug 10 2008, 11:45 PM
Wilhelm   Found a some 11 gauge 4.75" outside diameter ...   Aug 10 2008, 11:48 PM
iamchappy   Impressive!....   Aug 10 2008, 11:51 PM
Wilhelm   Cut the old hub out of a 914 swing arm and than we...   Aug 10 2008, 11:58 PM
SirAndy   :trophy: how does the brake attach? :idea: Andy   Aug 11 2008, 12:30 AM
Wilhelm   :trophy: how does the brake attach? :idea: And...   Aug 11 2008, 12:43 AM
sww914   What you've done looks great! Good ideas f...   Aug 11 2008, 12:52 AM
Wilhelm   What you've done looks great! Good ideas ...   Aug 11 2008, 02:03 AM
Phoenix 914-6GT   What you've done looks great! Good ideas...   Aug 11 2008, 02:19 AM
Mikey914   Nice. Saw a set of turbo twisties on CL locally an...   Aug 11 2008, 01:06 AM
neo914-6   Excellent work and great idea!   Aug 11 2008, 01:42 AM
Wilhelm   Since I can add the brake bracket for my caliper e...   Aug 11 2008, 02:08 AM
Rick_Eberle   Since I can add the brake bracket for my caliper ...   Aug 11 2008, 02:25 AM
roadster fan   Nice work, wish I had some of those tools :worshi...   Aug 11 2008, 03:16 AM
Wilhelm   Thanks for the info on the reinforcements! Th...   Aug 18 2008, 09:18 PM
Wilhelm   Here are the parking brakes set in place without t...   Aug 18 2008, 09:24 PM
r_towle   awesome work... I agree that what you did will ad...   Aug 18 2008, 09:27 PM
Krieger914   Nice work. Do you think the axles are going to hi...   Aug 18 2008, 09:44 PM
John   Wow! That is some excellent thinking. Are yo...   Aug 18 2008, 10:28 PM
SGB   Simply amazing. Wow that sweet. :)   Aug 18 2008, 10:32 PM
Wilhelm   As the axle would be going into a deeper hole, the...   Aug 18 2008, 10:55 PM
Todd Enlund   Damn, dude... that rocks. :headbanger:   Aug 18 2008, 11:19 PM
Wilhelm   Forgot to add this should anyone else be intereste...   Aug 19 2008, 12:19 AM
andys   Wilhelm, Just catching up after 5 days in Puerto ...   Aug 20 2008, 04:13 PM
ClayPerrine   Wilhelm, Just catching up after 5 days in Puerto...   Aug 20 2008, 10:06 PM
burton73   Wilhelm, Just catching up after 5 days in Puert...   Dec 8 2008, 11:28 PM
ClayPerrine   [quote name='ClayPerrine' post='1069525' date='Au...   Dec 9 2008, 09:43 AM
Brett W   One thing to keep in mind, on a unit bearing like ...   Aug 20 2008, 06:26 PM
andys   Clay, I've read that opinion before, but unfo...   Aug 20 2008, 11:11 PM
ClayPerrine   Clay, I've read that opinion before, but unf...   Aug 21 2008, 12:55 PM
andys   Clay, I've read that opinion before, but un...   Aug 22 2008, 03:06 PM
Brett W   The Carrera GT used a spot type caliper. http://...   Aug 21 2008, 01:15 AM
ClayPerrine   The Carrera GT used a spot type caliper. http:/...   Aug 21 2008, 12:56 PM
McMark   Beautiful... :drooley:   Aug 21 2008, 03:00 AM
Phoenix 914-6GT   Ummm... Can I have that rear suspension? :D   Aug 21 2008, 03:15 AM
Wilhelm   "I curious why you chose the 928 bearing? Mos...   Aug 21 2008, 12:34 PM
andys   "I curious why you chose the 928 bearing? Mo...   Aug 21 2008, 12:59 PM
ClayPerrine   For what its worth, even Wilwood is using a parkbr...   Aug 21 2008, 01:10 PM
Brett W   Glad I haven't bought the Wilwood spot caliper...   Aug 21 2008, 04:27 PM
seanery   nice project! it's very cool!!...   Aug 21 2008, 04:41 PM
charliew   I don't know why this additional challenge occ...   Sep 18 2008, 11:46 AM
Lou W   Very nice work. :beer2:   Nov 30 2008, 05:54 AM
burton73   Clay, This was Rich’s answer to my email on the...   Dec 9 2008, 03:39 PM
charliew   Wilhelm I have been anxiously waiting to see the r...   Jan 24 2009, 07:54 PM
Wilhelm   I'm anxiously awaiting the solution too! ...   Jan 24 2009, 10:49 PM
charliew   Oh yeah I forget about the weather everywhere but ...   Jan 25 2009, 08:54 AM
- Lo-Fi Version Time is now: 29th April 2025 - 07:21 AM
