jesiv |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California ![]() |
Ok I am starting to play. So I purchased the complete suspension from a drilled 5 lug conversion (complete front including rack and rear trailing arms with drilled 5 lug hub). My plan was to buy a sway bar, tubro tie rods, koni adjustable and then replace entire front suspension. I thought I was clear on what I was going to do.
Today I found a great deal on a freshly rebuilt 72 911 front suspension with 911 sway bar and torsion bars. It is a complete suspension minus steering rack and tie rods. So I am thinking I should install the 911 stuff. Or should I mix and match parts. (IMG:style_emoticons/default/dry.gif) The 911 brakes sure look nice (IMG:style_emoticons/default/piratenanner.gif) Also would you get 15 or 16 fuchs? (IMG:style_emoticons/default/WTF.gif) Regards, James |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,628 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I went with my original 4 cylinder front end but replaced the hub and rotor with a crossdrilled SC rotor and a billet hub available in the Classifieds here. Very nice product. Brake calipers can be M calipers from the early 911 but I am going to try something different. You can see them peaking out from behind that Fuch. Aluminum mmmmmm..... (IMG:style_emoticons/default/biggrin.gif)
In the rear, I went with PMB rebuilt and modified trailing arms. You can't get easier than that. Wheels are 16X6 Fuchs.. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:34 PM |
