Pulled the gas tank, A little more work than first thought! W/pics |
championgt1 |
Jun 17 2008, 10:05 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Well I decided to pull the tank after finding out there is no filter up front( pump has been moved up front) and seeing very bad fuel lines up front. Good thing I did, the filter sock was shot to say the least. The area under the tank is in fairly good shap with a few spots of rust and alot of dirt and grime. The rust is not structural which is good.
I am not sure if this is the first time the tank has been out or not. It is amazing what you will find in the area under the tank besides dirt, grime, and rust.(razor blades, paper towels, washer nozzle, snap-on tool, sanding disk, ect. ect.) Suprisingly the inside of the tank is pretty clean. The outside has a few areas of light rust which I will clean up and paint. So instead of replacing the filter it will be a little more involved. (While your in there syndrome) My plan is to clean the area under the tank with oil eater, and give it a hot water bath, use some mar-hyde to convert the rust and then paint everthing. This will be my first experience trying to git rid of rust and also painting. I hope it turns out good. Stay tuned for updates and pictures as I progress along. (IMG:style_emoticons/default/bye1.gif) Jack |
PeeGreen 914 |
Aug 25 2008, 04:00 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
The one at the very front of your car. There looks to be a few circles that are filled in. The cars came from the factory with those holes open and with plugs in them. Look at the picture of you wheel well that looks to the front. You'll see it. Right by the wiring harness.
Lo-Fi Version | Time is now: 29th June 2024 - 04:45 AM |
