jesiv |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California ![]() |
Ok I am starting to play. So I purchased the complete suspension from a drilled 5 lug conversion (complete front including rack and rear trailing arms with drilled 5 lug hub). My plan was to buy a sway bar, tubro tie rods, koni adjustable and then replace entire front suspension. I thought I was clear on what I was going to do.
Today I found a great deal on a freshly rebuilt 72 911 front suspension with 911 sway bar and torsion bars. It is a complete suspension minus steering rack and tie rods. So I am thinking I should install the 911 stuff. Or should I mix and match parts. (IMG:style_emoticons/default/dry.gif) The 911 brakes sure look nice (IMG:style_emoticons/default/piratenanner.gif) Also would you get 15 or 16 fuchs? (IMG:style_emoticons/default/WTF.gif) Regards, James |
jesiv |
Ok, so based on your experience, if I install 911 suspension... Will 15x6 or 16x6 fuchs just fit... No Problems? (IMG:style_emoticons/default/dry.gif)
Regards, James |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:48 PM |
