1.8 Check oil level hot or cold?, I've done a search in this forum but didn't see the answer. |
angerosa |
Aug 24 2008, 01:21 PM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
When my car is cold, oil level is at the min line. When it's hot it seems to be at the max line (maybe slightly above). Engine is always off when I check. What is the correct way.
type47 |
Aug 24 2008, 03:40 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
as i pull the dipstick, i wipe the oil off with a rag/paper towel at the end of the dipstick tube then reinsert for a second and pull it out again. (IMG:style_emoticons/default/idea.gif) i do that for the exact reason you stated that oil would be splashed up the stick and give a higher reading. just a possibility.
dw914er |
Aug 26 2008, 02:54 AM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
as i pull the dipstick, i wipe the oil off with a rag/paper towel at the end of the dipstick tube then reinsert for a second and pull it out again. (IMG:style_emoticons/default/idea.gif) i do that for the exact reason you stated that oil would be splashed up the stick and give a higher reading. just a possibility. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 15th January 2025 - 08:06 AM |
