New Fuse Box, Only on when ignition is on |
turnaround89 |
Aug 26 2008, 12:44 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
how can i run a fuse box so that when the ignition is in on position everything running off the fuse box will turn on, but when you turn the car off, it kills all the power? The reason i ask is bc i want to run a new fuel pump in the car but want a fuse for it, but i don't want the thing running all the time, that wouldn't be good at all. Does the stock fuel pump go through a fuse, if it does which one is it? Thanks everybody, with this last bit of help the car will be running today(i hope), not driveable, but i'll get to hear it run again (IMG:style_emoticons/default/biggrin.gif) !!!
swl |
Aug 26 2008, 08:43 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
which begs the question - do you still have a relay panel?
Lo-Fi Version | Time is now: 20th June 2024 - 05:55 AM |
