JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
I know I am going to get beat up hard for this one but here goes. I have been trying to tune my carbs for a while now but have had no luck. I got the car to idle great ( I followed Rich`s advice by taking the linkage off and tuning each side individually. I got all 4 cylinders reading the same with the snail. I reved the engine a little and it started to pop through the cylinder #2. I let it idle for a while and pulled cylinder #2 wire and the engine continued to run the same. I pulled the wire for cylinder #4 and it still ran the same. I than pulled #1 and it almost stalled and the same was true for #3. I was puzzled that it would run so good on 2 cylinders. I turned the engine off and started it with cylinder #2 and # 4 off. It started up and idled fine. I verified the plugs were good by swapping them in the cylinders that were good and I swaped the wires as well. If my timing was way off could this cause this or is more an issue with the cap and rotor? I am so close but this is killing me because I cant tune it if it is not running on all 4 cylinders. Any ideas what is going on?
JOE M |
I made a little mistake in my post--it`s the #2 and 3 cylinder not firing. I checked spark and there is spark but IMO it`s not great. I did a compression check on #3 and it is at 80~85. Again not great but it should fire and run. I also know that #1 has the lowest compresssion at about75. I am starting to think it`s more a carb setup issue or electrical issue ( possibly cap and rotor?). I checked the gap on plugs and it was about .028". I think that I should have the carbs rebuilt correctly because I dont have a clue what I am doing. If I keep touching it I am going to have a lawn orniment. I hate lawn orniments---. With that said I guess I should start from the beginning and check my valves clearance, than have the carbs rebuilt and go from there. This is so frustrating ( it seems like a no brainer).
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I made a little mistake in my post--it`s the #2 and 3 cylinder not firing. Whew! Then it's not both front cylinders or both rear cylinders--so it's not a flat cam! (IMG:style_emoticons/default/smile.gif) It could be pushrods not fully seated, but that's a much easier fix than a cam swap. --DD |
JOE M |
I made a little mistake in my post--it`s the #2 and 3 cylinder not firing. Whew! Then it's not both front cylinders or both rear cylinders--so it's not a flat cam! (IMG:style_emoticons/default/smile.gif) It could be pushrods not fully seated, but that's a much easier fix than a cam swap. --DD How do I determine if the pushrods are seated or not. Do I just take the valve covers off and watch when the cyclinders are at TDC. Like I said I have never really done anything at this level before. Thanks Joe |
Lo-Fi Version | Time is now: 27th June 2024 - 07:32 PM |
