nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
finally switching my tired old 1.7 with FI, to a 2.0 with dual weber 40's . what is the best fuel pump to install. my old one is up front so i assume the new guy will go there.also what should i do with the old return line (is the old bolt and clamp method safe?) and where should the filter go? thanks as always in advance (IMG:style_emoticons/default/biggrin.gif)
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I would suggest that you get a high quality carb pump from holley or others (CBperformance) and an adjustable regulator to keep the pressure in the range of 2-3 psi.
I would prefer to mount my fuel pump under the passenger side engine shelf in the stock location because low pressure pumps dont like to pull fuel up hill. they can push uphill alot better. Put the regulator in the engine bay so you can adjust it easily along with a fuel pressure gauge inline. Its not required to close off the return line and some/many people actually use the return line. The idea is to allow the unspent fuel to return to the tank thus keeping a fresh supply of cooler fuel at the ready for the carbs... Cooler fuel means better combustion. Rich |
Lo-Fi Version | Time is now: 30th June 2024 - 04:44 AM |
