JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
I know I am going to get beat up hard for this one but here goes. I have been trying to tune my carbs for a while now but have had no luck. I got the car to idle great ( I followed Rich`s advice by taking the linkage off and tuning each side individually. I got all 4 cylinders reading the same with the snail. I reved the engine a little and it started to pop through the cylinder #2. I let it idle for a while and pulled cylinder #2 wire and the engine continued to run the same. I pulled the wire for cylinder #4 and it still ran the same. I than pulled #1 and it almost stalled and the same was true for #3. I was puzzled that it would run so good on 2 cylinders. I turned the engine off and started it with cylinder #2 and # 4 off. It started up and idled fine. I verified the plugs were good by swapping them in the cylinders that were good and I swaped the wires as well. If my timing was way off could this cause this or is more an issue with the cap and rotor? I am so close but this is killing me because I cant tune it if it is not running on all 4 cylinders. Any ideas what is going on?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I need to be in and out tommorow.
Do you have a specific time you might be home?? Oh, so its one side of the motor not working, right. Swap the carbs...its the carbs. Stop thinking its anything else. Rich |
Lo-Fi Version | Time is now: 27th June 2024 - 07:24 PM |
