nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
finally switching my tired old 1.7 with FI, to a 2.0 with dual weber 40's . what is the best fuel pump to install. my old one is up front so i assume the new guy will go there.also what should i do with the old return line (is the old bolt and clamp method safe?) and where should the filter go? thanks as always in advance (IMG:style_emoticons/default/biggrin.gif)
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
2-3 PSI.
Carbs never need more than that. Any more Fuel pressure and you will see the carb start spitting fuel out... I think the last time I did carbs I went to AutoZone and bought whatever I found...by that statement I mean...I dont really care who makes it....its a simple electronic pump... To me, being able to find one on sunday is better than the name on the side of the pump... The regulator is a different story for me...high quality, easy to set, and leak free. Order that, get one from Summit or a local race shop. Get a really good one. Rich |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
2-3 PSI. Carbs never need more than that. Any more Fuel pressure and you will see the carb start spitting fuel out... I think the last time I did carbs I went to AutoZone and bought whatever I found...by that statement I mean...I dont really care who makes it....its a simple electronic pump... To me, being able to find one on sunday is better than the name on the side of the pump... The regulator is a different story for me...high quality, easy to set, and leak free. Order that, get one from Summit or a local race shop. Get a really good one. Rich Thanks for the great responses guys. I'm also about to install( or attempt to install) Weber 40's on a car today also. This info has been very helpful. |
nycchef |
[/quote] are you using s regulator? pay close attention to what you do. post pics, make diagrams i will be asking you a lot of ? real soon here is the first one... is the fuel regulator from the d-jet usable on carbs? i have 3 of them rich |
r_towle |
[quote name='nycchef' date='Aug 30 2008, 11:36 AM' post='1073298']
Thanks for the great responses guys. I'm also about to install( or attempt to install) Weber 40's on a car today also. This info has been very helpful. [/quote] here is the first one... is the fuel regulator from the d-jet usable on carbs? i have 3 of them rich [/quote] Nothing from the FI fuel pump nor regulator can be used on carbs. FI pump puts out 65 PSI. FI regulator drops is down to 28-32 and car go to 40. Carbs Fuel pump is 1.5-3 PSI. Carb regulator is 1.5-8 PSI normally. (in that range) the carbs regulator cannot handle 65 PSI input..it will leak right away and become a boat anchor in seconds. the FI regulator will not go down low enough for carbs and then you will shoot fuel out the carbs all over the motor... You need to buy two cheap items. An elec fuel pump, and a regulator. Rich |
nycchef |
You need to buy two cheap items. An elec fuel pump, and a regulator. Rich [/quote] cb performance regulator is $81.00 pump is only $53.00 will look for a cheaper regulator. |
hot_shoe914 |
[quote name='nycchef' date='Aug 30 2008, 03:08 PM' post='1073356']
[ You need to buy two cheap items. An elec fuel pump, and a regulator. Rich [/quote] cb performance regulator is $81.00 pump is only $53.00 will look for a cheaper regulator. [/quote] You can buy a fuel pump cheaper. I priced one today at a foreign car parts store for 35.00 |
Lo-Fi Version | Time is now: 27th June 2024 - 05:43 PM |
