klikkid3 |
Member ![]() ![]() Group: Members Posts: 111 Joined: 2-July 08 From: san bernardino Member No.: 9,242 Region Association: Southern California ![]() |
So I recently get done with my front bearing project and the car was running so smooth and nice (IMG:style_emoticons/default/driving.gif) that I had that fear in the back of my mind about when it was all going to end. Well today I was coasting down mountain ave when the light changed so I down shifted into third, and it started. The starter is staying engaged with or without the key in. I pulled over and popped the lid and disconnected the negative terminal. Checked the wiring at the selenoid which looked normal, every time I reconnect the battery the starter engages and attempts to start the car. What do you all think? There is the obvious replace the starter but any other suggestions? I have a tow kit on it so I will try and get it home to take a closer look. Help!
RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
On second look, I think it's just a trick of the perspective, light, etc.
Just unplug the red wire from the top connector for the moment and then hook up the battery again. It's a super easy test, and if the starter still engages, then you know that the solenoid has taken a big dump. |
klikkid3 |
On second look, I think it's just a trick of the perspective, light, etc. Just unplug the red wire from the top connector for the moment and then hook up the battery again. It's a super easy test, and if the starter still engages, then you know that the solenoid has taken a big dump. Ok it doesnt turn over when the red wire is taken off, I am predicting that the new starter switch shorted and melted and the yellow wire also melted somewhere in between and is shorting on metal which is causing the starter to engage. Is it possible to attach a new yellow wire and pull it all the way through the car to the ignition? |
Lo-Fi Version | Time is now: 24th June 2024 - 07:10 AM |
