clutch problems...... |
fuzzybear1981 |
Aug 31 2008, 02:42 PM
Newbie Group: Members Posts: 5 Joined: 8-June 08 From: uk Member No.: 9,146 Region Association: Europe |
I have done a 914 conversion on my vw beetle and i cant work the clutch asembly out......I push the pedal and it doesnt return?? is there supposed to be a spring of sorts there??
r_towle |
Aug 31 2008, 04:25 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You are using the beetle transmission?
If so, your pressure plate will push back against the throw out bearing and that will release the tension on the cable. The pedal assembly has a round spring that holds the pedal up, but this spring is resting on the floorboards to gets its lever. If you are using the right parts for the clutch, pressure plate, and flywheel, that may be ok. You may have just mounted the pedal assembly wrong or there is a hold in the floor...that happens. Rich |
Lo-Fi Version | Time is now: 6th January 2025 - 04:21 PM |
