jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
What is the smallest compressor ( tank storage and PSI) that can be used with air tools in my gaurage. Usually I see pretty good size tanks on wheels; I would like to keep the size down to the tight space I have to work with.
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
If you ever decide to do any sandblasting you will need a 20 or 25 cfm compressor and that means 220 single phase or three phase if you have it the electric cost are the 3 ph. cost half as much.
If you use a 50 foot hose the requirements at the end of the hose means the pressure must usually be doubled at the beginning of the hose to have enough at the end. I use a 50 gallon storage tank, It's actually a old hot water tank, to pull from and catch water right before the hose. It also helps on the compressor recovery. When I use the straight line sander, the compressor runs continously and it's a 19 cfm two stage 5 hp. 60 gallon tank upright. I hook up an additional 2 1/2 hp 220 single phase portable compressor when I sandblast. I can barley get by on the larger compressor when I use the bead blast cabinet. The electric meter is a blur. I bought one of the kits to make a compressor out of a 1600 type 1 vw but haven't put it together yet. It is susposed to make a lot of cfm ( seems like 56) for blasting. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:47 AM |
