mattp |
Member ![]() ![]() Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 ![]() |
I have a 2056 with a VDO oil pressure sending unit coming off the top of the engine, one end has the oil pressure the other the temp, it worked before removing it from original engine now it doesnt?
I hooked black and green wire to it, but getting no reading at all, do the sending units fail? |
mattp |
I have the black and green wire and the red and green wire, currenlty the pressure sunding unit come up out of the top of the block near the distributor, it then has a "T" one ind attaches to the plastic hose that send the oil pressure to oil opressure guage, the other looks like a sending unit, I thought it was the temp guage, it may be the oil pressure sending unit?
If it is the oil pressure sending unit then where does the oil temp wire attach to? How do I check which sensor it is? At some point this last weekend the oil light wernt on in the car after making a few consecutive hard turns, so I assume the sending unit is the oil pressure unit?? Ugh, thanks for help. Matt |
Lo-Fi Version | Time is now: 24th June 2024 - 11:30 PM |
