retrotech |
retrotech ![]() ![]() Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 ![]() |
Can some one tell me the difference between 4 cyl. ratios & 6 cyl. Basically are the gears raios closer on which one? Which has the lower ratio, ie lower max speed per gear.
Thanks |
retrotech |
So if you were running a 6, with 4 gear ratios, wouldn't that be good? Closer, lower, mid range gears with more torque, and a longer [higher rpm] 5th gear.
Lo-Fi Version | Time is now: 25th June 2024 - 11:52 PM |
