> Sound from the rear-Part II, Bushing not greaed properly
jim_hoyland
post Sep 8 2008, 08:32 PM
Get that VIN ?
The sound finally went away with an heavier application from the grease gun into the zirks yesterday. I used a heavy duty tractor bearing grease
I have been told that the bushing should have silicone grease on their outer surface and under the flange, which makes sense now. So I'll pull the arms, remove the bushings and try the silicone grease.
The creak started to come back today, albeit less noisy.
Any tip on do's / dont's on greasing bushings will be appreciated
Eric_Shea
post Sep 8 2008, 10:51 PM
PMB Performance
Rich, are you familiar with the hardness measurement of these bushings? Have you actually seen a set of these or, are you giving recommendations off the 94D bushings that are common out there?
Jim, got your emails thanks. I'll post here as well so others can get a straight answer.
Hard bushings "do" have this tendancy if tight on the shaft which is why I recommend the zerks. We have had some fit loose in the arms which is why I recommended the shim stock in the bushing thread. They simply shouldn't be moving in the arm, they should pivot smoothly on the shaft.
From reading your second email it sounds like you've licked the problem with an ample amount of lube... perfect. It may come back again as the arm works it's way into a solid fit. After that, it should be normal maintance lubrication. We've found that a loose(er) bushing will not do this. It's best to have the slide on the arm when cool or to have the shaft pivot freely when finally installed in the arm. That being said I personally like to have them tighter at first (like yours) and let them work themselves in.
With Thomas on the job you're in good hands.
jim_hoyland   Sound from the rear-Part II   Sep 8 2008, 08:32 PM
r_towle   My first piece of advice would be to bin them. Get...   Sep 8 2008, 08:49 PM
r_towle   If you must stick with the plastic. take a dremel...   Sep 9 2008, 11:57 AM
Eric_Shea   Rich, are you familiar with the hardness measureme...   Sep 8 2008, 10:51 PM
r_towle   Rich, are you familiar with the hardness measurem...   Sep 9 2008, 08:11 AM
r_towle   Its an opinion, nothing to get personal about....   Sep 9 2008, 11:16 AM
Eric_Shea   Frankly, I think (know) you're talking out of ...   Sep 9 2008, 09:26 AM
r_towle   Frankly, I think (know) you're talking out of...   Sep 9 2008, 09:49 AM
Eric_Shea   Wonder why I would respond the way I do? :idea:...   Sep 9 2008, 10:58 AM
r_towle   sounds like a sales response. his are squeaking/cr...   Sep 9 2008, 11:11 AM
mikez   Hmmm, on a recent install of hard bushings I got l...   Sep 9 2008, 11:41 AM
Eric_Shea   I responded with the correct information in my v...   Sep 9 2008, 11:46 AM
736conver   No your first response was to throw away the pro...   Sep 9 2008, 12:02 PM
greenie   Guys, Just a thought ... maybe it's not the b...   Sep 9 2008, 12:05 PM
jim_hoyland   :rotfl: :rotfl: :rotfl: :rotfl: I switched over...   Sep 9 2008, 12:10 PM
Eric_Shea   Grooves are unnecessary. ;) Zerks are in the ins...   Sep 9 2008, 12:15 PM
r_towle   I would shut up if you offered help and advice ins...   Sep 9 2008, 12:30 PM
Eric_Shea   Hmmmm... let's see :idea: I get it! I...   Sep 9 2008, 12:53 PM
mikez   :popcorn: :cheer: :rotfl:   Sep 9 2008, 01:33 PM
r_towle   I will quote myself so you can remember. you agre...   Sep 9 2008, 03:22 PM
Eric_Shea   :jerk: I pasted what I typed to Jim in a person...   Sep 9 2008, 03:24 PM
736conver   Rich you first response was. You trashed Eric w...   Sep 9 2008, 03:33 PM
r_towle   I did not know that Eric made these bushings. I kn...   Sep 9 2008, 03:36 PM
Eric_Shea   Like what Rich? I've simply replied to ever...   Sep 9 2008, 03:57 PM
r_towle   Ok, so my answer was not straight...grease fittin...   Sep 9 2008, 05:09 PM
Eric_Shea   :jerk: Take your meds.   Sep 9 2008, 06:25 PM
Rusty   Gentlemen, We're all friends here... looking ...   Sep 9 2008, 07:29 PM
mikez   http://web01.genmay.com/userav/avatars/sobeavatar....   Sep 9 2008, 08:14 PM
rhodyguy   ha. what a thread. DING! gentlemen, to your co...   Sep 9 2008, 09:16 PM
sixnotfour   whatever, I got rollers. my plastic ones wont e...   Sep 9 2008, 09:23 PM
rhodyguy   rolls it out. calling...   Sep 9 2008, 09:29 PM
Eric_Shea   I've got Rollers on one car and Elephants on t...   Sep 9 2008, 10:41 PM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 10:17 PM
