Sound from the rear-Part II, Bushing not greaed properly |
jim_hoyland |
Sep 8 2008, 08:32 PM
Get that VIN ? Group: Members Posts: 9,572 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The sound finally went away with an heavier application from the grease gun into the zirks yesterday. I used a heavy duty tractor bearing grease
I have been told that the bushing should have silicone grease on their outer surface and under the flange, which makes sense now. So I'll pull the arms, remove the bushings and try the silicone grease. The creak started to come back today, albeit less noisy. Any tip on do's / dont's on greasing bushings will be appreciated |
Eric_Shea |
Sep 9 2008, 09:26 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Frankly, I think (know) you're talking out of your ass.
They're not plastic and they're a great bushing if installed properly. These 70D's should last as long as the factory bushings if maintained properly. If you have no experience with 70D bushings you shouldn't pretend that you do. |
Lo-Fi Version | Time is now: 6th January 2025 - 10:25 PM |
