Sound from the rear-Part II, Bushing not greaed properly |
jim_hoyland |
Sep 8 2008, 08:32 PM
Get that VIN ? Group: Members Posts: 9,572 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The sound finally went away with an heavier application from the grease gun into the zirks yesterday. I used a heavy duty tractor bearing grease
I have been told that the bushing should have silicone grease on their outer surface and under the flange, which makes sense now. So I'll pull the arms, remove the bushings and try the silicone grease. The creak started to come back today, albeit less noisy. Any tip on do's / dont's on greasing bushings will be appreciated |
r_towle |
Sep 9 2008, 03:36 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I did not know that Eric made these bushings.
I knew that Jim asked what to do with his plastic bushings. I offered advice. My opinion, remove them and get a good setup that will last a long time, not squeak, and is hard. No slap at Eric personally, its a product. Eric, did your parent raise you to be like this? Would you have the courage to talk to someone face to face like this? I doubt it on both counts. Rich |
Lo-Fi Version | Time is now: 6th January 2025 - 10:18 PM |
