'70 D-jet runs terrible cold, great when warm,, Please share your wisdom |
Porsche Rescue |
Sep 9 2008, 03:45 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Car starts when cold (not quickly, but it does start, air temp. 80 degrees), then it is a bitch to keep it going. Once on the road and warmed up it performs beautifully.
I have checked the Aux. Air Valve and it is sucking when cold, plugged when hot. I replaced the head temp sensor even though the old one tested OK. The new one helped a little, but not near enough. I have studied Brad Anders' site and can't come up with any other ideas of what to check. I have to believe the ignition system is fine because it runs so well when warm. I have checked timing and dwell and they are on spec. Any suggestions out there? |
Porsche Rescue |
Sep 9 2008, 06:12 PM
Thanks Mark and Rich. Anders mentions the resistor and I think I'll try that. He suggests somehow wiring it to a switch in the cabin because it will cause rich running when warm. Think I'll wire one in and worry about the switch if it solves the problem.
I got an extra Porsche rebuilt ECU with the car. In checking Anders' numbers, it appears to be for a '73 2.0. I know my new temp sensor is correct for the car, but have no idea what ECU I have in the car. Guess I will pull it out and see. PO was the original owner of the car and is very knowledgeable. Wonder why his spare ECU is for a 2.0? |
Lo-Fi Version | Time is now: 6th January 2025 - 03:48 PM |
