415PB |
Member ![]() ![]() Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 ![]() ![]() |
I finished my rebuild about a month ago. I've driven my teener for only about 20 miles since. I have a small puddle of oil on the garage floor, which I believe is coming from the small window in between the engine and tranny. I drove it today for a couple of miles, parked it in the garage and it immediately began to drip oil from the above location. I checked my oil and it is about an eighth inch to a quarter inch above the full mark. I guess I over filled the oil. I replaced the rear main seal during my rebuild and can't imagine that this is the problem. It is definately oil and not gear oil. How hard would it be to remove just the tranny and not the engine. I don't think I can go through removing the engine again, but I will if I have too. Any suggestions are greatly appreciated.
Thanks, Rod |
thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
It's pretty easy to remove just the tranny and I've done to change the rear crank seal. Remove starter, un-do driveshafts, chock the rear of the engine so it doesn't hang on its mounts and whip out the gearbox -two gearbox mounts and the three remaining bolts on the engine (starter is one of the four). Don't forget the earth strap! (I always do)
You can lower the 'box on a car jack its not that heavy. Might be wise to get a clutch alignment tool.... I didn't have one and used a deep socket that fit. May as well get a new thrust bearing for the flywheel too while your in there. Make sure to index your flywheel so it goes on the same position it came off for balance purposes. . -j |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:46 PM |
