V8 guys - Overheating Fuel Pump in the Front Trunk.., Where do you mount it? |
cobra94563 |
Sep 15 2008, 10:02 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I have an overheating fuel pump in the front trunk. I think it overheats because of the heat coming off the radiator and screws up the pump enough to so I loose fuel pressure down to 1psi.
The pump is a new holley red w/a holley regulator. The pump gets so hot you cannot keep you hand on it. I iced it down a bit and my pressure immediately comes back up. I considered the heat could be from the pump, but the wiper motors also get too hot to touch. So where do you mount your pump (if not in the front trunk)? Or what kind of pump do you have (if in the front trunk)? ..or maybe I have to cut more openings..? (IMG:style_emoticons/default/idea.gif) |
cobra94563 |
Sep 15 2008, 02:49 PM
Thanks for the pix, Tony.
My pump is not located much different than yours. Your's doen't get really hot to touch?? Headlight motor and even, battery get hot. My fender holes are not as large as yours. Maybe I'll open them up some more. The car is NOT overheating, so I stopped cutting. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:40 PM |
