V8 guys - Overheating Fuel Pump in the Front Trunk.., Where do you mount it? |
cobra94563 |
Sep 15 2008, 10:02 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I have an overheating fuel pump in the front trunk. I think it overheats because of the heat coming off the radiator and screws up the pump enough to so I loose fuel pressure down to 1psi.
The pump is a new holley red w/a holley regulator. The pump gets so hot you cannot keep you hand on it. I iced it down a bit and my pressure immediately comes back up. I considered the heat could be from the pump, but the wiper motors also get too hot to touch. So where do you mount your pump (if not in the front trunk)? Or what kind of pump do you have (if in the front trunk)? ..or maybe I have to cut more openings..? (IMG:style_emoticons/default/idea.gif) |
BIGKAT_83 |
Sep 16 2008, 03:30 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Can one of you guys tell me why you don't use a SBC pump that is mounted on the block?? I thought it was due to the pump not fitting due to the engine mount and bar, but I find it hard to believe that is the case... Am I wrong ??? Thom If your using a electric water pump you can use the stock SBC block mounted mechinacal fuel pump. Otherwise either the waterpump or alternator are in the way. Bob |
Lo-Fi Version | Time is now: 25th September 2024 - 10:58 PM |
