dbgriffith75 |
TheGrif ![]() ![]() ![]() Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest ![]() |
So basically I'm just curious here on who's opinion is what and why. I might have seen a similar post a while back but I don't remember for sure.
My personal opinion is carbs. I don't know what a new injector for a 914 is going for but generally speaking carb kits are cheaper than new injectors. Plus, I like trying to fine tune carbs- if one is set right the engine can be extremely efficient. My teener is set up for carbs and I plan to leave it that way. |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
QUOTE Low end power? Bow to FI as it has better low end power. That should be spelt BLOW With the FI that came with the car the low end sucked. On a slow corner I would have to go for first. With the Webers I only need to go for first when I stop. The FI also had a 'Lag' at take off. But the fuel milege was great, LA to San diego on a half a tank. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
QUOTE Low end power? Bow to FI as it has better low end power. That should be spelt BLOW With the FI that came with the car the low end sucked. On a slow corner I would have to go for first. With the Webers I only need to go for first when I stop. The FI also had a 'Lag' at take off. But the fuel milege was great, LA to San diego on a half a tank. Your FI was seriously out of tune. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/stirthepot.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:45 PM |
