'70 D-jet runs terrible cold, great when warm,, Please share your wisdom |
Porsche Rescue |
Sep 9 2008, 03:45 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Car starts when cold (not quickly, but it does start, air temp. 80 degrees), then it is a bitch to keep it going. Once on the road and warmed up it performs beautifully.
I have checked the Aux. Air Valve and it is sucking when cold, plugged when hot. I replaced the head temp sensor even though the old one tested OK. The new one helped a little, but not near enough. I have studied Brad Anders' site and can't come up with any other ideas of what to check. I have to believe the ignition system is fine because it runs so well when warm. I have checked timing and dwell and they are on spec. Any suggestions out there? |
Porsche Rescue |
Sep 9 2008, 08:40 PM
I will do some ECU checking on Thursday. No time to play tomorrow.
Porsche Rescue |
Sep 19 2008, 03:08 PM
Took a week, but finally made time to do some more checking.
Removed the ECU plug and did all the Brad Anders resistance checks and everything meets his specs. My ECU is the correct 015 unit for a '70. I replaced the head temp sensor (probably unnecessary). Both old and new are the correct Bosch 012 unit. I have a back-up ECU (037) but I think it requires a different temp sensor and the '73 resistor. My next step is to try a resistor as suggested above. Here's where my ignorance of things electronic really shows. Asked the guy at Radio Shack for a 1/4 or 1/2 watt 270 ohm ballast resistor. All he had was 220 ohms or 330 ohms. Opted for the 220. Word "ballast" is nowhere to be seen. After investing all of 99 cents for 5, I am thinking I don't have the right component. Before wiring one into the sensor line, thought I should check. So, do I have a resistor that might help? And is 220 too far away from 270 ohms? |
Lo-Fi Version | Time is now: 6th January 2025 - 04:03 PM |
