> '70 D-jet runs terrible cold, great when warm,, Please share your wisdom
Porsche Rescue
post Sep 9 2008, 03:45 PM
Saving and Enjoying Old Porsches
Car starts when cold (not quickly, but it does start, air temp. 80 degrees), then it is a bitch to keep it going. Once on the road and warmed up it performs beautifully.
I have checked the Aux. Air Valve and it is sucking when cold, plugged when hot.
I replaced the head temp sensor even though the old one tested OK. The new one helped a little, but not near enough.
I have studied Brad Anders' site and can't come up with any other ideas of what to check. I have to believe the ignition system is fine because it runs so well when warm. I have checked timing and dwell and they are on spec.
Any suggestions out there?
Rand
post Sep 19 2008, 03:32 PM
Cross Member
Tweaking with resistors is cool and all, but it's off topic. This thing should start and purr flawlessly without having to modify the system. Something else is wrong.
But if the temp sensor and AAR are good, this is quite a puzzle. So is it just low idle on cold start? Anything else specific?
Porsche Rescue   '70 D-jet runs terrible cold, great when warm,   Sep 9 2008, 03:45 PM
Bartlett 914   Make sure you have the correct CHT and the Correct...   Sep 9 2008, 04:36 PM
r_towle   you could add the 270 Ohm resistor to your CHT lin...   Sep 9 2008, 04:54 PM
Porsche Rescue   Thanks Mark and Rich. Anders mentions the resistor...   Sep 9 2008, 06:12 PM
r_towle   the spare ECU is a 2.0 liter ecu, but from what I ...   Sep 9 2008, 07:01 PM
orange914   the spare ECU is a 2.0 liter ecu, but from what I...   Sep 9 2008, 08:22 PM
Porsche Rescue   I will do some ECU checking on Thursday. No time t...   Sep 9 2008, 08:40 PM
Porsche Rescue   Took a week, but finally made time to do some more...   Sep 19 2008, 03:08 PM
Rand   Tweaking with resistors is cool and all, but it...   Sep 19 2008, 03:32 PM
Porsche Rescue   My instinct is the same as yours, something else m...   Sep 19 2008, 03:57 PM
Rav914   CSV?   Sep 19 2008, 04:07 PM
Porsche Rescue   As I understand, CSV only injects at low temp (50 ...   Sep 19 2008, 04:12 PM
mattillac   bad MPS? sticky decel. valve? the AAR might work o...   Sep 19 2008, 04:39 PM
Rand   CSV isn't kicking in at his ambient temps. Dec...   Sep 19 2008, 04:48 PM
toon1   Does the car back fire on accel before it's wa...   Sep 19 2008, 05:40 PM
mattillac   could this be a bad TPS or need TPS adustment? ano...   Sep 19 2008, 07:09 PM
Rav914   Didn't know that about the CSV. Subscribed. ...   Sep 19 2008, 11:06 PM
toon1   could this be a bad TPS or need TPS adustment? an...   Sep 20 2008, 12:32 AM
Porsche Rescue   All who offered help last fall, please see my post...   Feb 7 2009, 02:43 PM
orange914   All who offered help last fall, please see my pos...   Feb 7 2009, 03:32 PM
r_towle   I will run down the issues that it could be. The ...   Feb 7 2009, 04:05 PM
r_towle   TPS pic at Idle with flapper closed on throttle bo...   Feb 7 2009, 04:08 PM
r_towle   One more thing Fuel pressure and new fuel filter....   Feb 7 2009, 04:11 PM
Porsche Rescue   It pains me to write this..........and Rich Towle,...   May 30 2009, 05:54 PM
Bleyseng   I don't know, its just that if the valves are ...   May 31 2009, 09:14 AM
- Lo-Fi Version Time is now: 6th January 2025 - 03:53 PM
