'70 D-jet runs terrible cold, great when warm,, Please share your wisdom |
Porsche Rescue |
Sep 9 2008, 03:45 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Car starts when cold (not quickly, but it does start, air temp. 80 degrees), then it is a bitch to keep it going. Once on the road and warmed up it performs beautifully.
I have checked the Aux. Air Valve and it is sucking when cold, plugged when hot. I replaced the head temp sensor even though the old one tested OK. The new one helped a little, but not near enough. I have studied Brad Anders' site and can't come up with any other ideas of what to check. I have to believe the ignition system is fine because it runs so well when warm. I have checked timing and dwell and they are on spec. Any suggestions out there? |
mattillac |
Sep 19 2008, 04:39 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
bad MPS? sticky decel. valve? the AAR might work ok but are hoses ok?
all simple things to check at least. check plugs as mentioned and also the gap. |
Lo-Fi Version | Time is now: 6th January 2025 - 04:01 PM |
