AvalonFal |
Member ![]() ![]() Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region ![]() |
Do the front sway bar drop links ('74) have a top and bottom or doesn't it matter which way they are installed? My links seem to have a very slight curve at one end (not perfectly straight) that might be from wear, or is it the way they're made?
Paul |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I also thought the rod came out of the cylindrical end (that holds the bushing) at an angle of some sorts. Not "perfectly" straight.
I'm away from the car right now but I could check later. The theory (if I recall) is the drop link angles slightly away from the body down to the attachment on the a-arm. |
AvalonFal |
I also thought the rod came out of the cylindrical end (that holds the bushing) at an angle of some sorts. Not "perfectly" straight. I'm away from the car right now but I could check later. The theory (if I recall) is the drop link angles slightly away from the body down to the attachment on the a-arm. So the angled end of the link is at the top?? Paul |
Lo-Fi Version | Time is now: 26th June 2024 - 02:52 AM |
