Pulling hubs into rear bearings...need some advice |
computers4kids |
Sep 28 2008, 10:30 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I've been converting my project car from 4 to five lug and have run into a snag. After installing new bearings in the rear, I attempted to draw the rear hubs into the bearing using the tool below. No matter how careful I am, the hub starts to go in crooked so I stop, not wanting to force it it.
So what's the trick to getting these puppies started straight? It seemed like an easy enough task. I do have the rear arms mounted, thinking it would be better held in place. Would pulling the arms and having the laying flat be any better. Thanks Attached image(s) |
sww914 |
Sep 28 2008, 11:38 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I freeze the hubs and warm up the inner races to about 90-100 degrees and I use anti-seize on the parts that I want to slide. The last 2 sets that I did I was able to push them in by hand almost all the way.
zambezi |
Sep 28 2008, 11:48 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
I freeze the hubs and warm up the inner races to about 90-100 degrees and I use anti-seize on the parts that I want to slide. The last 2 sets that I did I was able to push them in by hand almost all the way. +1 on freezing the axle shaft. A night in the freezer does wonders for the interferance fit of the two parts. JIM |
r_towle |
Sep 29 2008, 10:50 AM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I freeze the hubs and warm up the inner races to about 90-100 degrees and I use anti-seize on the parts that I want to slide. The last 2 sets that I did I was able to push them in by hand almost all the way. +1 on freezing the axle shaft. A night in the freezer does wonders for the interferance fit of the two parts. JIM Is that why I fit in the car better in the winter than in the summer???? Rich |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:28 PM |
