computers4kids |
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None ![]() |
I had a machine shop redrill my new zimmerman rear 4lug rotors to 5lug. The holes are slightly off and the rotors will not sit flush--they hang-up on the studs. I opened the holes up a bit and it is much better. Unfortunately, they need even more opening which I'm concerned because to do this will make some of the holes loose around the studs. Is this safe?
Choices, do I open the holes up so the rotor will slip around the studs even though some of the studs will be sloppy knowing the wheel studs once torqued will hold things correctly? or Do I just go out and buy a set of 914-6 rear rotors and cut my losses? If so does someone have a source near Visalia, CA that I can get fast...I want to put my 5 lug conversion together this weekend? Pelican won't ship for 5 days. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,507 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Jeeeze! what kind of machine shop were they? I did mine myself on my drill press. It was easy. (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 18th June 2024 - 05:52 AM |
