New Fuel Pump! No power... |
slim72914 |
Oct 1 2008, 09:40 PM
Member Group: Members Posts: 153 Joined: 4-July 07 From: Mesa, AZ Member No.: 7,874 |
Hey all. I recently finished my new fuel pump install and relocate to the front under the fuel tank. Got it running and all tuned in and then it just stopped pumping... No power. I checked the factory wires where I tapped in to them to extend the wiring to the front and there is no power even before the area where I soldered my connector in. Is there an easy way to check the relay? I tried switching it with one of the other ones in the board (dont remember which one but it had the same part#) and it still did not turn the pump on. Any help??? Thanks all.
swl |
Oct 3 2008, 07:37 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
generally speaking the 12pin is carrying stuff to the engine. Ignition power, starter, tach, backup light switch... Lot of power going through there but mostly on the way to the engine. Supply for the board itself comes in at the top through the 14pin
Lo-Fi Version | Time is now: 26th September 2024 - 05:21 PM |
