A different way to hook up 911 e-brakes, Another way to do the 911 parkbrake -merged threads |
Wes V |
Oct 4 2008, 07:07 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I think I've come up with a totaly new way to hook up 911 parking brakes. It involves making up longer hybrid cables.
It's not complex, doesn't cost tons, and is about as straight forward as possible. It functions exactly as intended in the 911. Here is a teaser photo; (IMG:http://www.performanceforum.com/wesvann/914a/my-rear-brake/b-mrb1.jpg) Here is a link to my write-up on how I did it (it's a preliminary write-up). hybrid cables Wes (can somebody please find me the photo that I've seen on this site where somebody used a cable end block at the parking brake lever that had set screws) |
jj83118 |
Oct 5 2008, 09:32 PM
Newbie Group: Members Posts: 33 Joined: 12-May 05 From: Colorado Springs, CO Member No.: 4,066 Region Association: None |
I welded the crimped ends back on with a MIG welder and I did not weld all the way to the end. You don't want to weaken the cable.
I don't think I would attempt to silver solder or braze the ends as you will be fighting capillary action as the solder wicks its way up the cable. I'll have to check header clearance once the engine is put back in my car (it's been out for quite some time now). If there is interference, I might be able to put an Adel clamp on the cable and attach it to the trailing arm. |
Lo-Fi Version | Time is now: 28th September 2024 - 09:09 AM |
