smooth_eddy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 ![]() |
Two years ago I bought a Stihl string trimmer. I have found that it isimpossible to start when the gas/oil mixture is over a month old. It runs great if it gets started every week, but let is sit a while and I end up pulling my guts out trying to start it. I tried to use some old starting fluid (maybe 12 yrs old) and stihl no luck. Does starting fluid have a shelf life??? Makes me want to go back to an electric weed eater.
Eddy |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If it doesn't spray, then it's too old. That's the only time I've had it go bad. We've got a diesel tractor that needs a shot when it gets cold (it has a special port for starting fluid), and I've had a can last for several years.
Make sure your oil/fuel mixture is correct. If it's too heavy with oil it can cause starting and fouling problems. More than likely it's the spark plug. Champion makes an upgrade plug for two cycles that does work better and last longer. I have a Stihl string trimmer, and backpack blower and they both start without too much trouble. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Lo-Fi Version | Time is now: 20th June 2024 - 06:21 AM |
