> Engine Suggestions, What would you do?
jmill
post Oct 16 2008, 01:02 PM
Green Hornet
I've got a 73 17. and a 2.0. I can't afford a Raby 2270 now but until then I want the best bang I can get for the buck. A stock engine won't work for me. What is the cheapest way to upgrade without breaking the bank? Which block do I start with? I can toss about $2,000 at it. Can I build a stroker for that kind of money? Would I be better to build a small displacement rever? What p/c's do I go with? Thanks in advance guys.
sww914
post Oct 17 2008, 05:11 PM
I think that here can be a happy balance between less expensive and perfect.
Everyone who tells you that every piece inside the engine should be brand new or reconditioned is right. It is better to renew everything every time. That said, I will never spend $10,000.00 on a goddamned VW Van motor.
Tolerances exist to determine how worn a given part is and when it should be replaced. The very finest parts will last longer, be more reliable and build more power. That's not the question. The real question is how much can you spend and is it enough to build an engine that will work for you. For 2K you can almost get it done. The big variable is the heads. If all these heads have cracks then all the cars running around have cracked heads. What fails? What are the failures?
My car has been running cracked heads for 9 years. I expected it to last a season or two, I didn't have another grand to throw at the heads right then.
It is possible to touch up the valves and seats, replace the guides if they need it, replace the springs if you're going to rev it or add a big cam and run it. Buy some Weber 44's, a cam and lifters, some 96's, bearings and gaskets and build an engine. Will it be as good or last as long? Hell no!
Will it be good enough? Probably.
jmill   Engine Suggestions   Oct 16 2008, 01:02 PM
Todd Enlund   I've got a 73 17. and a 2.0. I can't aff...   Oct 16 2008, 01:14 PM
Chris Hamilton   As far as I have seen, the best bang for your buck...   Oct 16 2008, 01:15 PM
orange914   $2000... not gonna happen with a type IV. ma...   Oct 16 2008, 02:24 PM
Todd Enlund   $2000... not gonna happen with a type IV. m...   Oct 16 2008, 03:26 PM
davep   With that kind of a budget, I'd do much as I a...   Oct 16 2008, 03:06 PM
toon1   Are both the 1.7 and 2.0 in running condition? ...   Oct 16 2008, 03:18 PM
SirAndy   I've got a 73 17. and a 2.0. I can't aff...   Oct 16 2008, 03:48 PM
jmill   You were right Todd thats 2k just for the engine. ...   Oct 16 2008, 05:14 PM
Todd Enlund   You were right Todd thats 2k just for the engine....   Oct 16 2008, 05:37 PM
Cap'n Krusty   I have two sets of typically used 2.0 heads at the...   Oct 16 2008, 05:28 PM
904svo   Talk to Jake, ever now and then some body backs ou...   Oct 16 2008, 05:52 PM
jmill   Thanks for all the info guys. I think I know what...   Oct 17 2008, 07:34 AM
carr914   Run the existing engines and save your money till ...   Oct 17 2008, 08:02 AM
Mark Henry   Guys wanting engines done on the cheap is just ano...   Oct 17 2008, 08:16 AM
jmill   Sorry to hear your getting out of the engine busin...   Oct 17 2008, 02:51 PM
sww914   I think that here can be a happy balance between l...   Oct 17 2008, 05:11 PM
749142   Well, with my experience i built a couple 2056s an...   Oct 18 2008, 12:44 AM
sww914   749142, I agree with you. The point of my whole po...   Oct 18 2008, 01:06 AM
DBCooper   You're right. When you build your own engines...   Oct 18 2008, 07:02 AM
sww914   That's why I don't scuff & squirt peop...   Oct 18 2008, 01:01 PM
749142   sww914. thats true. i thought you were saying neve...   Oct 19 2008, 12:59 AM
Jake Raby   More skill is required when building an engine wit...   Oct 19 2008, 11:34 AM
azbill   More skill is required when building an engine wi...   Oct 19 2008, 06:37 PM
Jake Raby   I have no idea!   Oct 19 2008, 06:53 PM
jmill   It can be done right without breaking the bank. I...   Oct 20 2008, 08:04 AM
- Lo-Fi Version Time is now: 9th September 2026 - 08:12 AM
