echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
I have a 75 with a 1.8 & l-jet.
I recently purchased this car as a non-runner but in good overall structural condition. I am now at the point where it cranks by the key and I get spark and fuel but the injectors are not functioning. the checklist of things I have checked are: 1. Compression, good all the way around 2. Spark, also good all the way around 3. Fuel, good pressure, fuel pump runns when the AFM flap is moved and when the starter is engaged. 4. ignition switch replaced by me for a non-functioning one. 5. The dual relay were replace by a used unit that seems to work 6. The thing I know is wrong is, the injectors are not opening or getting a charge to open. I understand that normally the signal to power the injectors comes from the coil & they open twice per crank rotation in a non-sequential fashion. Are they powered by the ECU as well? Where should I start looking next? I bet if I can get the injectors to fire this puppy will start right up. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Bingo! That's the wire that tells the ECU when to fire the injectors. Goes to the point side of the coil, and the engine will not run without it. The Cap'n
Lo-Fi Version | Time is now: 26th June 2024 - 05:53 AM |
