Losing oil, out of hole near cyclingder three |
turnaround89 |
Oct 20 2008, 04:44 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Everytime i drive my car, there is always a little pool of oil that collects behind a little hole by cylinder 3, the oil collects on top of the cooling tins in the back corner of the car. The hole is next to the nut that holds the intake on, its about .5inch diameter or smaller(didn't measure it just guessing) What can i do to stop this oil issue? I also noticed this same hole is on the opposite side of the engine but instead of being behind the intake it is in front of the intake by cylinder 2, no oil comes out of that hole. Maybe the oil isn't coming out of the holes but somewhere else. All i know is that oil collects by cylinder 3 on top of the cooling tins. thanks everybody!! help my car not spew oil, my dad hates oil spots when i pull into the driveway
jsayre914 |
Oct 20 2008, 04:59 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
what kinda oil are you using?? I had the same problem pool in the rear tin, I changed to the cheapest 20-50 motoroil and added a can of purple stuff. I think it was called " compression in a can" from flaps. I wiped the tin clean, and never saw the puddle again. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 05:01 AM |
