1.7 injectors into a 2.0 (Temporary), 2.0's sat for 24 years |
tracks914 |
Oct 25 2008, 08:15 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Here is the deal, I have a 1.7 that was running well 2 years ago.
I bought a 2.0 this past winter. It had sat for about 24 years. The injectors, fuel gauge, fuel pump etc. were all seized. (Varnished) I was able to free up the fuel pump and injectors(injectors took 24 volts and lots of carb cleaner but I was able to get them to click and then seal up ok) I'm now trying to start my engine (after a complete tear down, reseal and gasket) but it doesn't fire on all cylinders and I have one cylinder with gas coming out the exhaust. I was thinking about getting my 1.7 out of storage and pulling the injectors just to get it running and move it around so I can store it for winter. Does anyone see much of a problem with this? Tx Doug |
davesprinkle |
Oct 26 2008, 11:13 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
I'm now trying to start my engine (after a complete tear down, reseal and gasket) but it doesn't fire on all cylinders and I have one cylinder with gas coming out the exhaust. Doug, I had these symptoms when the diaphragm on the fuel pressure reg ruptured. This failure passed raw fuel through the pressure reg vent line into the plenum. The engine wouldn't start, and raw fuel was dripping out of the #3 exhaust port. Pull off the vent line and run the pump. If fuel is pissing out, replace the reg. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:26 PM |
